BraceworksCalculation overview
Command
Path
Calculation Overview
Braceworks
The Calculation Overview dialog box displays the results of the latest calculation or system check. It opens as the result of calculation and system check commands, but it can also be displayed at any time.
To view the calculation overview:
Select the command.
The Calculation Overview dialog box opens.
Parameter
Description
Feedback
The status indicator allows you to see at a glance whether the system meets safe compliance limits. Green indicates there are no errors or overloaded supports/cross sections, yellow indicates caution as safe limits are being approached, and red means there are critical problems or overload conditions. If the indicator is blank, the information is insufficient.
Beneath the indicator, the system status is described as unsolvable (with errors preventing calculation), solvable, or it does not have any data. The system must be considered solvable, with no critical errors, for calculations to occur.
A solvable system may still have serious errors that must be addressed; for example, a hoist or cross section could be dangerously overloaded, as evidenced by the solvable calculation.
Calculation Time
Displays the amount of time, in seconds, that it took for calculations to complete
Workload Support
Summarizes the workload percentage upon supports (hoists and bridles) in the system
Workload Cross Section
Summarizes the workload percentage upon cross sections in the system
Information
Errors and Warnings
Click this tab to view issues in the drawing; each issue corresponds to a label placed in the drawing
Filter
Filters the list of issues by type; select All to see all of the issues
Type
Icons indicate the type of issue. Double-click on a row to select and center the associated label in the drawing.
Icon_info.png Information: General issue that will not cause problems with calculations
Icon_warning.png Warning: Issue that should be resolved, since it could affect calculations
Icon_error.png Danger: Critical issue that prevents calculations from proceeding, or prevents calculations from being useful
Category/
Description/
ID
Indicates the type of structural element with an issue, describes the issue, and displays the issue’s unique identifier
Export
Automatically sends the error data to a Calculation Overview - Errors worksheet; if one already exists, the worksheet name is automatically incremented
Cross Section Workload
Click this tab to view the workload status for cross sections
Filter
Status
Icons indicate the status of the cross section workloads. Double-click on a row to select and center the associated cross section in the drawing.
Warning: Cross section is nearing its threshold
Danger: Cross section is over its threshold
Icon_good.png Pass: No issues
Cross Section
Identifies the cross section
Value/
Max/
Displays the workload applied to each cross section, the maximum defined deflection limit, and the percentage of the workload. The total workload is summarized in Workload Cross Section on the left of the dialog box.
Export
Automatically sends the data to a Calculation Overview - Cross Section workload worksheet; if one already exists, the worksheet name is automatically incremented
Hoist Workload
Click this tab to view the workload status for hoists
Filter
Status
Icons indicate the status of the hoist workloads. Double-click on a row to select and center the associated hoist in the drawing.
Warning: Hoist is nearing its threshold
Danger: Hoist is over its threshold
Pass: No issues
ID
Identifies the hoist
Type
Indicates the type of hoist
Value/
Max/
Displays the workload applied to each hoist, the maximum defined limit, and the percentage of the workload. The total workload is summarized in Workload Support on the left of the dialog box.
Export
Automatically sends the data to a Calculation Overview - Hoist workloads worksheet; if one already exists, the worksheet name is automatically incremented
Analyses
Click this tab to view detailed information about the most recent calculation
Hoists
Displays the minimum, average, and maximum hoist workload
Cross Sections
Lists the status and maximum workload for each cross section in the calculation
System
Displays information about the structural systems used in the calculations, with the total number of various rigging elements
List box functionality
Performing calculations
Performing system check calculations
Displaying and correcting errors
