SpotlightCreating the rigging system
Placing trusses
Tool
Tool set
Truss
Rigging
The Truss tool and the Magnet tool share the same position in the Rigging tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The Truss tool places a section of truss on the drawing. Depending on the resource selected, the truss may be a straight, curved (or circular), hinge, or corner element.
You can place one truss at a time, or place multiple straight trusses, to create a truss line. Trusses can be inserted horizontally, vertically, or at a custom hanging angle. In Auto Connect mode, the trusses connect to existing trusses, forming a system. When Auto Connect is disabled, the trusses do not connect to existing systems.
Use the Data Tag tool to add a label to the truss; see Adding data tags and labels.
Mode
Description
Auto Connect
When enabled, connects the inserted truss to the current truss system with geometrical precision; also generates a preview of connected trusses that are being moved
Truss symbol
Select the truss to insert
Single Insertion
Inserts a single truss object on the guideline
Distributed Insertion
(straight truss only)
Inserts multiple truss objects along the full length of the guideline
Horizontal Placement
Places horizontal trusses; the hanging angle is 0 (zero) degrees
Vertical Placement
Places vertical trusses; the hanging angle is 90 degrees
Custom Placement
Places trusses at the specified Hanging Angle
Maintain class of symbol
Uses the class specification from the symbol definition; disable the mode to insert the truss into the active class instead
Hanging Angle
Specify the hanging angle for Custom Placement
A truss object whose symbol definition cannot be located will display with default geometry, until a replacement symbol is assigned.
Concept: Rigging objects
Placing a new truss line
Adding trusses to an existing system
Adding hinges to an existing system
Placing a new hinge
Truss properties
