Creating a 2D rack contents worksheet
Command |
Path |
Make Rack Equipment Worksheet |
Context menu |
This command creates a worksheet listing the equipment installed at each rack position on a 2D equipment rack, and it places the worksheet on the right side of the rack. This shows the details of what is mounted at the rack U position opposite the worksheet row, which is helpful at installation.
To create a 2D rack contents worksheet:
In the Rack Elevation design layer, right-click on a 2D equipment rack and select the command.
The Rack Equipment Columns dialog box opens.
Parameter |
Description |
Drag and drop a number to a different location to change the display order of columns in the worksheet |
Use |
Select which columns to include in the worksheet. A check mark in the Use column indicates that the column will be included. |
Column |
Displays the column names that can be included in the worksheet |
Select All Columns / Deselect All Columns |
Either select all of the columns, or deselect all of the columns |
Select the worksheet columns and their display order.
The 2D rack contents worksheet is placed on the right side of the rack.
