Creating holes
Drilled holes
Mode
Tool
Tool set
Hole - Drilled
Detailing
Multiple drilled and tapped hole tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Both 2D and 3D drilled holes are available. The 3D drilled hole is a solid object that can be subtracted from any other solid object to create accurate 3D models of molds, dies, and many other machine parts (see Subtract solids).
To insert a drilled hole:
Click the tool and mode.
Parameter
Description
Hole Diameter
Enter the hole diameter
Total Depth
Enter the depth of the hole
Hole Type
Select one of the hole types
Drill Point Angle
For Blind Hole types, indicate the angle of the drill point at the bottom of the hole
Hole Style
Select the hole style
Diameter
For counterbored or countersunk hole styles, enter the diameter of the counterbore or countersink
Depth
For counterbored hole styles, specify the depth of the counterbore
Angle (deg.)
For countersunk hole styles, specify the angle of the countersink
View
Select the 2D view
Show Center Line
Draws the 2D drilled hole with center line(s)
Tapped holes
