Offset links
Mode
Tool
Workspace: Tool set
Roller Chain - Offset Link
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple roller chain tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The offset link connects a roller link and a pin link.
To insert an offset link:
Click the tool and mode.
Parameter
Description
Standard Chain No. (Pitch)
Select the standard ANSI or ISO roller chain number; the pitch is given as a reference
Show Pins
(3D only)
Displays the pins
Linear roller chains
Circular roller chains
