Rivets (DIN)
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Rivet (DIN) |
Fasteners |
Multiple rivet tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a rivet (DIN):
Click the tool and mode.
Parameter |
Description |
Diameter |
Select a diameter in millimeters |
Length |
Enter the length under the rivet head (or overall length for the countersunk rivet) |
Head Type #1 |
Select a head type for one end of the rivet
Head Type #2 |
Select a head type, if any, for the other end of the rivet |
View (2D only) |
Select the 2D view
Show Center Line (2D only) |
Draws the rivet with center line(s) |
