Shafts
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Shaft |
Architect and Spotlight: Machine Components Landmark: Add tool to workspace |
The Shaft tool and Shaft - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The Shaft tool allows the creation of a shaft consisting of multiple straight, tapered, and threaded shaft segments.
To insert a shaft segment:
Click the tool and mode.
Click the Configuration button from the Object Info palette to add, delete, or modify shaft component segments (see Shaft segment properties).
