Tubular rivets
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Tubular Rivet |
Fasteners |
Multiple rivet tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a tubular rivet:
Click the tool and mode.
Parameter |
Description |
Size |
Select a size in millimeters |
Length |
For a custom length value, deselect Use Standard Length Increments and enter the length |
Form |
Select one of the rivet types
View (2D only) |
Select the 2D view
Show Uncompressed Length (2D only) |
Displays the uncompressed rivet length |
Use Standard Length Increments |
Automatically adjusts the length to the nearest increment based on DIN standard sizes; deselect to enter a custom length value |
Show Center Line (2D only) |
Draws the rivet with center line(s) |
