Bearings
Ball bearings
Mode
Tool
Workspace: Tool set
Ball Bearing
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple ball bearing, roller bearing, and needle bearing tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a ball bearing:
Click the tool and mode.
Parameter
Description
Bearing Type
Select from a variety of single ball or double ball radial and angular bearings
Single Row, Radial
Single Row, Angular
Double Row, Radial
Double Row, Angular
Inside Diameter
Specify the inside diameter of the bearing
Outside Diameter
Specify the outside diameter of the bearing
Width
Enter the width of the bearing
View
(2D only)
Select the 2D view
Show Detail
(2D only)
Indicate whether to display a detailed 2D view of the bearing
Show Center Line
(2D only)
Draws the bearing with center lines
Section
(3D only)
Draws a section of the bearing
Highlight Rollers
(3D only)
Highlights the rollers within the bearing in black
