Extension springs: End view
Mode
Tool
Workspace: Tool set
Extension Spring - End
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple extension spring tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert an extension spring - end view:
Click the tool and mode.
Parameter
Description
Wire Diameter
Enter the wire diameter
Outside Diameter
Specify the outside diameter of the coiled section of the spring
Ends at Right Angles
Indicate whether the spring ends are displayed at right angles to each other
Spiral
Select either a Left Hand or Right Hand spiral direction
Draw Center Lines
Draws the spring with center lines
