Needle bearings
Mode
Tool
Workspace: Tool set
Needle Bearing
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple ball bearing, roller bearing, and needle bearing tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a needle bearing:
Click the tool and mode.
Parameter
Description
Bearing Type
Select one of the bearing types
Inside Diameter
Specify the inside diameter of the bearing
Outside Diameter
Specify the outside diameter of the bearing
Width
Enter the width of the outer ring
Number of Rows
Enter the number of bearing rows
View
(2D only)
Select the 2D view
Show Inner Ring
Displays the bearing inner ring
Show Detail
(2D only)
Indicate whether to display a detailed 2D view of the bearing
Show Center Line
(2D only)
Draws the bearing with center lines
Section
(3D only)
Draws a section of the bearing
Highlight Rollers
(3D only)
Highlights the rollers within the bearing in black
