Feature control frame
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Feature Control Frame
Architect and Spotlight: Dims/Notes Landmark: Add tool to workspace |
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
A feature control frame consists of a geometric characteristic symbol, up to two tolerance areas, and up to three datum reference areas.
To insert a feature control frame:
Click the tool and mode.
To add a leader and marker, click the Selection tool from the Basic palette and drag the control points on the object. Edit the marker from the Attributes palette (see Marker attributes).
Parameter |
Description |
Rotation |
Specifies the number of degrees to rotate the object (0.00 is horizontal) |
Text Style |
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text. |
Geometric Characteristic |
Select the geometric characteristic symbol, if any
Composite Box |
Increases the size of the geometric characteristic box; this is used when placing a second feature control frame
Tolerance Area #1/#2 |
Includes Tolerance Area #1 and/or Tolerance Area #2 |
Tolerance |
Enter the tolerance value |
Show Diameter Symbol |
Displays a diameter symbol along with the tolerance value
Material Condition |
Choose the material condition, if any
Statistical Tolerance |
Displays a statistical tolerance symbol
Projected Tolerance Zone |
Displays a projected tolerance zone symbol |
Zone Height |
Enter the maximum projected tolerance zone height when a projected tolerance zone symbol is displayed |
Place the PTZ symbol outside the FCF |
Places the projected tolerance zone symbol outside and to the bottom of the feature control frame
Primary/Secondary/Tertiary Datum Reference |
Includes the primary, secondary, and/or tertiary datum reference |
Reference |
Enter the desired reference letter |
Select a material condition, if any
Leader Position |
Select left or right |
