Geometric dimensioning and tolerancing note
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Geom Dim and Tol Note
Architect and Spotlight: Dims/Notes Landmark: Add tool to workspace |
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The Geom Dim and Tol Note tool inserts a notation symbol and text specifying the dimension of round, square, counterbore, and/or countersink holes, and unit ratio for conical and/or flat tapers. Alternatively, a depth symbol and associated text can be inserted.
To insert a geometric dimensioning and tolerancing note:
Click the tool and appropriate mode.
To add a leader and marker, click the Selection tool from the Basic palette and drag the control point on the object. Edit the marker from the Attributes palette (see Marker attributes).
Parameter |
Description |
Rotation |
Specifies the number of degrees to rotate the object (0.00 is horizontal) |
Text Style |
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text. |
Precision |
Select the decimal place rounding value for the hole size and depth |
Note Type |
Select the style of the note marker
Hole Size/Taper |
Enter the diameter for round, square, counterbore, and countersink holes; enter the unit ratio for conical and flat tapers |
Tolerance |
Sets whether the hole size/taper has a single, double, limited, or no tolerance
Top/Bottom |
Enter the value that is added to or subtracted from the base dimension to determine the upper/lower limit of the dimension |
Depth/Angle |
Enter the depth for round, square, and counterbore holes (if the depth is zero or less, it is not displayed); enter the angle for countersink holes |
Tolerance |
Sets whether the depth/angle has a single, double, limited, or no tolerance
Top/Bottom |
Leader |
Enter text to display before the dimension |
Trailer |
Enter text to display after the dimension |
Leader Line Position |
Select to place the dimension leader line to the right or left side of the object |
Shoulder Length |
Specifies the length of the leader line’s shoulder |
