Unconstrained baseline dimension
Mode |
Tool |
Workspace: Tool set |
Unconstrained Baseline
Unconstrained Linear Dimension
Fundamentals: Dims/Notes Architect, Landmark, Spotlight: |
Unconstrained Baseline mode creates a series of connected dimension lines, with each line segment measuring the distance from the initial starting point (the base point).
To create a series of unconstrained baseline dimension lines:
Click the tool and mode, and then select a Dim Std (dimension standard).
Click to set the measurement start point.
Click to end the measurement of the first segment.
Move the cursor away from the object to the desired offset location.
In a 3D view, the first two clicks determine the X axis of the plane where the dimension will be placed; move the cursor to rotate the dimension plane. The dimension plane can be horizontal or vertical to the layer plane, or aligned to adjacent faces of a 3D object being dimensioned.
Click to place the dimension line.
Move the cursor to the end of the next segment and click to set its endpoint.
Continue setting segments.
Double-click to end the baseline.
