SpotlightInserting an LED screen
Mode
Tool
Tool set
LED Screen
Event Design
The Light-emitting Diode (LED) object simulates a variety of low-resolution LED screens in arrays on a base structure.
To insert an LED screen or array:
Click the tool and the insertion modes.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Module Shape
Select a shape for the screen modules in the array
Tile Flat
Creates rectangular-shaped modules
Tile Cap
Creates rectangular-shaped modules with frosted caps
Disk Flat
Creates round modules
Disk Cap
Creates round modules with frosted caps
Tube
Creates tube-shaped modules
Dome
Creates dome-shaped modules
Width
Specifies the width of each module in the array
Height
For tiled arrays, sets the height (length) of each module in the array
Cap Depth
For capped arrays, sets the depth of each module’s cap
Tube Orientation
For tube arrays, specifies whether the tubes are oriented vertically or horizontally
Length
For tube arrays, sets the length of one of the tube modules
Build Array Based On
Module Counts and Spacing
Sets the size of the entire LED array based on the number of modules specified in the horizontal and vertical directions, as well as the horizontal and vertical spacing distance set between the modules
Overall Dimensions and Spacing
Sets the size of the entire LED array based on the specified array width and height, as well as the horizontal and vertical spacing between the modules; the screen count is automatically calculated
Overall Dimensions and Module Counts
Sets the size of the entire LED array based on the specified array width and height, as well as the number of modules specified in the horizontal and vertical directions; the spacing is automatically calculated
Array Width/Height
Specifies the width and height of the entire LED array, when the array is based on overall dimensions
Horizontal/Vertical Spacing
Specifies the spacing between modules in the horizontal and vertical directions, when the array is based on spacing parameters
Horizontal/Vertical Count
Specifies the number of modules in the horizontal and vertical directions, when the array is based on the module counts
Module Total
Displays the total calculated number of modules in the array
Width/Height (Calc.)
Displays the calculated width and height of the array, when determined by module count and spacing
H/V Spacing (Calc.)
Displays the calculated module spacing in the horizontal and vertical directions, when the array is determined by the overall dimensions and module counts
H/V Count (Calc.)
Displays the total number of modules in the horizontal and vertical directions, when the array size is determined by the overall dimensions and module spacing
Pixels Per Module H/V
Specifies the number of horizontal or vertical pixels for each module (for calculation purposes only; does not affect the module display)
Array Size (Pixels)
Displays the total number of pixels for the entire LED array
Array Aspect
Specifies the aspect ratio of the array
Base Structure
Select a base structure for the array; modify the appearance of the structure by selecting Class LED Array Parts and then editing the structure class
Blocks
Creates a structure of individual blocks bases for each module
Frame
Creates a single frame for the entire array
Curtain
Creates a single background for the array
Web
Creates a webbed structure behind the modules
Vert. Strips
Places the LED modules in vertical columns
Horiz. Strips
Places the LED modules in horizontal rows
None
Does not create a base structure for the array; displays only the LED modules
Base Width
Specifies the width of blocks, vertical or horizontal strips, or the entire frame
Base Height
Specifies the height of blocks, vertical or horizontal strips, or the entire frame
Base Depth
Specifies the depth of blocks, vertical or horizontal strips, or the entire frame
Horizontal Inset
Sets the horizontal distance (margin) between the horizontal edge of the base structure and the array
Vertical Inset
Sets the vertical distance (margin) between the vertical edge of the base structure and the array
Pleat Width
For curtain or web structures, specifies the pleat width of the curtain (2D only for web structures)
Pleat Depth
For curtain or web structures, specifies the pleat depth of the curtain (2D only for web structures)
Webbing Width
For web structures, sets the width of the connecting web segments
Tilt
Specifies the tilt angle of the screen array
Simple 3D
Creates a single textured 3D polygon to represent the screen modules; this speeds rendering when each module does not need to be shown individually
Edit Array Image
Opens the Edit Screen Image dialog box
Array Image
Displays the name of the current screen image
Wattage
Enter the required wattage, for power consumption calculations and reporting
Note
Adds a note, which can be placed in the drawing with the Text Options
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels
Default Text Positions
Restores text labels to their default positions
Classes
Opens the Classes dialog box, to specify class naming for the various portions of the LED screen. This allows portions of the LED screen to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <LED Screen Class> to place the LED screen element in the same class as the LED screen.
Class Prefix: Specifies an optional default root class naming standard for all LED screen parts; click Assign Default Classes With Prefix to begin all LED screen class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all LED screen elements to the standard, using the Class Prefix if there is one.
LED screen elements: For each portion of the LED screen, specifies the class name standard; the class names shown here are applied to the elements.
Update
Updates the object when changes have been made to the Object Info palette parameters
Load Information
An LED screen is considered a distributed load in Braceworks calculations; if the screen is inserted parallel to a rigging object, it is considered to be a load on that structure. Load information is used for Braceworks calculations and reports (Braceworks required).
Include in Calculations
Includes the LED screen in Braceworks calculations; deselect to exclude the object from participating in structural calculations
Load Group Name
The load category is always Video for LED screen objects
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations
Distributed Weight
Enter the distributed weight of the LED screen object; changes here also affect the Total Weight value
Total Weight
Enter the total weight of the object
Position
Displays the name of the associated rigging object, if the LED screen is attached. Optionally, attach this object to a rigging object, or change the rigging object association, by entering the Position Name of the rigging object. Delete the name to break the association.
For other methods to attach loads, see Making the attachment.
Setting the image on the video screen
Formatting video screen object labels
Concept: Attaching loads to rigging objects
