Design SuiteReplacing slab styles from the Object Info palette
Slab styles applied to existing slabs can be replaced with a different slab style.
A slab replacement situation may also occur if pasting a styled slab from another file.
To replace a slab style:
Select one or more slabs.
From the Object Info palette, select Replace from the Style list.
The Slab Replacement dialog box opens. Specify the new slab style.
Parameter
Description
Slab style list
Click the slab style list. From the Resource Selector, double-click a different slab style to apply it.
Previews
The left preview shows the current slab style, and the right preview shows the replacement slab style selected in the slab style list. Preview slabs are drawn from top to bottom, so the top of the preview indicates the top part of the slab as it will be drawn. The red line indicates the datum component of each slab style; replacement is aligned to the datum.
Replacement options
Select whether to replace the current settings for slab height, class designations, drainage preferences, texture assignments, Energos data (Architect required), and slab data with those of the new slab.
If the slab is a hardscape slab, some architectural parameters do not apply.
If slabs with different slab styles were selected for replacement, the current slab preview is blank and components do not display.
Deleting and/or replacing slab styles from the Resource Manager
Slab preferences
Creating slab styles
Applying slab styles
