Inserting bathtubs and showers
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Bath-Shower
Furn/Fixtures |
The Bath-Shower tool provides access to a variety of standard configurations available from the Resource Manager, in addition to individual objects created using the tool. The tool can be used to create your own style resources (see Concept: Plug-in object styles).
To insert a bathtub or shower fixture:
Click the tool and mode.
Do one of the following:
Click Active Def on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter |
Description |
Style |
Replace, remove, or edit the current style, or create a new plug-in object style for this object. Editing a style changes all instances in the file that use the style. |
Hide Style Parameters |
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette |
Depth |
Enter the fixture depth |
Width |
Enter the fixture width |
Rim Height |
Enter the fixture’s rim height |
Config |
Select the shape of the bathtub or shower |
Surround |
Creates a surround for the fixture; enter the surround height |
Back Ledge |
Creates a back ledge for the fixture; enter the ledge’s width and height |
Bevel |
Enter the bevel size |
Drain Offset |
Enter the drain offset size |
Side Thickness |
Enter the thickness of the sides |
Show 3D Detail |
Displays the bath-shower in 3D views |
Click on the drawing to place the object, and click again to set the rotation.
Optionally, create a style resource from the object (see Standard plug-in object styles without catalog options).
