Exporting IFC projects
Command |
Path |
Export IFC Project |
File > Export |
Vectorworks project files can be exported to .ifc, .ifczip, and .ifcxml formats.
Export to IFC Versions 2x3 and 4 is supported. The export of a project to an IFC file is based on specifying the geometry and associated data needed for the use of the exported file. This specification is called a Model View Definition (MVD), which is a subset of all the geometry and data in a building model. MVDs have been created by international, national, or local groups to standardize information exchange for various purposes, such as design coordination, collision/clash detection, structural analysis, and element quantity analysis. You can use MVDs to automate the export, or manually define a custom set of geometry and data to be exported.
You can export a wall with components as a single IFC entity (IfcWall or IfcWallStandardCase), or you can split the wall into the individual components (IfcBuildingElementPart) for estimation purposes. If any component has been modified to have a different height from the rest of the wall, the components are automatically exported as building element parts.
To export a Vectorworks file to IFC:
For best results, the following are recommended before export:
In the Vectorworks preferences, set the 3D Conversion Resolution to “Low,” to reduce file size.
Set the view to Top/Plan.
Zoom the view into a small, simple corner of the model.
Select the command.
The Export IFC Project dialog box opens.
Specify the overall project export options, site information, and author data for each pane of the Data tab. Many of the fields are required by the IFC specification; they're automatically mapped to their IFC equivalent for inclusion in the IFC file header information.
Parameter |
Description |
Export Options |
Sets export parameters for the file |
File Format |
Select whether to export an .ifc, .ifczip, or .ifcxml file |
IFC Version |
Select the IFC version |
Model View |
Select the MVD that specifies the geometry and data required for export. CV 2.0 - Architecture is an official buildingSMART International MVD for exporting architectural models for coordination with structural and building services models. Extended Vectorworks Model View allows you to customize the geometry and data to be exported in conjunction with the Export Options for data exchange workflows without a standard or official MVD. This MVD exports the following elements that exceed the CV 2.0 MVD: 3D geometry as proxy objects (IfcBuildingElementProxy) Linear/angular/arc/slope dimensions North arrow Break line Text nodes (with IFC data attached) IES VE is a custom MVD to exchange model information with the IES-Virtual Environment platform to conduct building energy performance simulation and analysis. COBie/Facilities Management MVD enables the handover of graphic and non-graphic facility management information to the building manager. It includes the international version of COBie/COBie2 exchange requirements. Simplified Geometry exports walls as IfcWallStandardCase, merging all components into one extrude. Slabs are exported as multiple slab instances (one slab for each component). Reference View MVD (IFC4 only) exports geometry to be used as a reference model only. The model is not converted to native objects, and will not be modified by the receiver. This MVD is useful for visual presentations, coordination planning, clash detection, quantity take-offs, and so on. The model view and any add-on views are included as information in the IFC file header. |
Add-on Views |
Select optional information to be added to the model view at export. Quantity Take Off writes element quantity data to specific IFC data fields for use by costing/estimating applications. 1st Level Space Boundaries exports planes that represent the contact surface between a Space object and an adjacent surface, like a wall, floor, or ceiling. These boundary planes also indicate the placement and extents of openings, such as doors and windows. (Many energy analysis programs require this element.) |
Export Visible Objects Only |
Exports objects within visible classes only (the selection of layers for export is handled by the Layer Mapping options). When deselected, exports any objects required by the Model View selection. |
Export Site Model |
For drawings with a site model, this option exports the site model geometry and enables site model layers to be mapped on the Layer Mapping tab |
Export Custom Property Sets |
Exports custom Psets that were specified in the Manage Custom Property Sets dialog box for objects’ IFC data, for models not explicitly defined in the Model View definition, or when using the extended Vectorworks model view |
Export Solids Operations as BREPs |
Depending on the receiving application and data exchange requirements, solids operations may need to be simplified to a surface model, also known as a boundary representation (BREP) to display correctly and be properly identified |
Export Text in Unicode Format |
The Unicode format is more reliable for double-byte characters (text representing characters from such alphabets as Japanese, Chinese, and Cyrillic) but it must also be supported by the receiving application |
Export Walls/Slabs by components |
Exports the components of walls and slabs as sub-elements, for estimation purposes |
Project Data |
Name |
Type the project name |
Phase |
Enter the construction phase information |
Project Type |
Specify the type of project |
Project Description |
Enter a description of the project |
Building Permit ID |
Enter the building permit information |
Gross Area (Planned) |
Enter the total planned area for the entire project |
Currency Code |
Select the currency code (such as EUR for Euro, USD for US dollars) |
Time Unit |
Enter the time unit for the project |
Default Classification |
Select the project classification code; if User-defined is selected, enter the default classification |
Author Data |
Enter the information for the primary author of the file |
Role |
Select the author’s professional role; if User-defined is selected, enter the role title |
Category |
Click Look Up to open the Look Up <Default Classification> Category dialog box; the classification list displayed is determined by the Default Classification selection on the Project Data pane. Select the classification category. If the Default Classification is user-defined, User-defined is selected; enter the category. The selected Category displays. |
Author Addresses |
Enter pertinent information related to the physical location of the author’s place of business |
Organization Data |
Enter pertinent information related to the professional organization in charge of the project |
Role |
Select the organization’s professional role; if User-defined is selected, enter the role title |
Category |
Organization Addresses |
Enter pertinent information related to the physical location of the organization’s place of business. If the author address data and the organization address data are identical, click Copy Author Addresses to complete the telecom and postal information automatically. Subsequent edits made to either pane remain unique to the pane. |
Site Data |
Specify site information for the project location, regardless of whether site model data is selected for export. If the file contains georeferenced information, IFC 2x3 exports geolocated coordinates, and IFC 4 exports geolocated coordinates plus the specified coordinate system for the file. See Specifying document georeferencing. If the file is not georeferenced, but the site latitude/longitude and elevation values are known, enter them here. |
Site Address |
Enter address information for the project site |
Building Data |
Specifies the IFC properties associated with the building |
ID/Name/Description |
Enter the building’s ID, name, and description |
Category |
Gross Planned Area |
Specifies the total planned area for the building, used for programming purposes |
Reference Elevation/Site Reference Elevation |
Enter the elevation above sea level for the building and the building site |
Occupancy Type |
Specifies the occupancy classification, defined according to the presiding national building code |
Primary Construction Type |
Specifies the main fire use for the building, assigned from the fire use classification table as given by the relevant national building code |
Secondary Construction Type |
Enter any ancillary fire use for the building, assigned from the fire use classification table as given by the relevant national building code |
Sprinkler Protection |
Indicates whether the building has sprinkler protection, and if so, whether it is automatic (the selection is reflected on the Layer Mapping tab, where it can be overridden for an individual story) |
Year of Construction |
Enter the year when the building was built |
Landmark Status |
Indicates a building with special historical landmark designation |
Building Address |
Enter address information for the building; if the site address and building address are identical, click Copy Site Address to complete the postal information automatically. Subsequent edits made to either pane remain unique to the pane. |
Click the Layer Mapping tab to specify which layers to export, and the Story Name to assign to them at export. If specified, this includes the site model. For a project initially set up with stories, mapping is done automatically so that the layers assigned to the building stories are automatically included in the Mapped Layers list and are mapped to an appropriately named story (Vectorworks Architect or Landmark required). Mapping can also be controlled manually.
Specify the associated building or site data for each of the mapped layers.
Parameter |
Description |
Vectorworks Story Name |
Specify the mapping options for each story, and for the site model, if it is selected for export on the Data tab. As each story is selected, its associated layers display for mapping. Files set up with a story structure automatically map the story layers for export. |
IFC Story Name |
Displays the name assigned to the currently mapped layers for export; change the story name if necessary |
Available Layers |
Lists Vectorworks layers available for mapping; lists the layers associated with the number of stories and the story selected in the Story/Site Selection list |
Number of Stories |
Displays the number of stories in the file, which determines the number of stories available in the Story/Site Selection list. If the number of stories entered here is different from the number of stories set up for the file, additional layers display for possible mapping for the current story. This allows greater export flexibility, to override the story structure in the file and assign certain layers to different stories at export. |
Mapped Layers |
Lists layers that have been selected for export; they are associated with the Story Name entry |
Add > |
Adds available Vectorworks layers to the Mapped Layers list for export |
< Remove |
Removes mapped layers from the export list, returning them to the Available Layers list |
Mapped layer data |
Specifies IFC properties for selected mapped story layers |
Above Grade |
Indicates whether the story is fully above ground |
Entrance Level |
Indicates whether the story includes an entrance for the building |
Specifies whether the story includes sprinkler fire protection, and if so, whether the sprinklers are automatic; initial settings match the sprinkler protection setting on the Data tab |
Planned Areas, Gross/Net |
Indicates optional gross and net planned areas, used for design and programming purposes |
Either save the export settings, or export the project.
To save the parameter settings in the Export IFC Project dialog box, without exporting the project, click Save Settings. The parameters and options are saved, and the Export IFC dialog box closes.
Click Export to export the project.
Indicate the file name and location in the Save As dialog box.
