Placing lighting pipe ladders
Tool |
Tool set |
Lighting Pipe Ladder
Rigging |
Insert and configure a lighting pipe ladder object with the Lighting Pipe Ladder tool. Lighting pipe ladders function as rigging objects, so lighting devices and other loads can attach directly to the ladder. Lighting pipe ladders support full 3D rotation, and they can be used to create schematic views.
In addition to individual objects created using the Lighting Pipe Ladder tool, you can access a variety of standard lighting pipe resources and custom styles (see Concept: Plug-in object styles).
Mode |
Description |
Point Insertion
Inserts the ladder vertically with two clicks to place and set the rotation |
Rectangle Insertion
Inserts the ladder horizontally by clicking two diagonal points |
Width |
Sets the ladder’s width, for use with Point Insertion mode |
Height |
Sets the ladder’s height, for use with Point Insertion mode |
Preferences
Opens the object properties dialog box to set the default preferences for lighting pipe ladders |
Style |
Opens the Resource Selector to select a symbol for placement; double-click a resource to activate it |
To insert a lighting pipe ladder:
Click the tool.
Do one of the following:
Click Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
To insert a vertical ladder, click Point Insertion mode and set the ladder’s Width and Height.
To insert a horizontal ladder, click Rectangle Insertion mode.
Click twice in the drawing area to draw the lighting pipe ladder according to the modes selected.
Optionally, create a style resource from the object (see Creating plug-in object styles).
Parameter |
Description |
Roll Angle |
Rotates the lighting pipe ladder on its X axis; the pipe rotates around its insertion point |
Hanging Angle |
Rotates the lighting pipe ladder on its Y axis; the pipe rotates around its insertion point. When this angle is adjusted, attached load objects may appear to overlap in Top/Plan view. |
Rotation |
Rotates the lighting pipe ladder on its Z axis; the pipe rotates around its insertion point |
Style |
Replace, remove, or edit the current style, or create a new plug-in object style for this object. Editing a style changes all instances in the file that use the style. |
Hide Style Parameters |
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette |
General |
Ladder Width/ Height |
Specifies the lighting pipe ladder dimensions |
Guides |
Select how to draw the ladder based on the preview guide rectangle: on the ladder center, inside, or outside |
Number of Rungs |
Specifies the number of ladder rungs |
Evenly Spaced Rungs |
Spaces the rungs evenly within the ladder frame; deselect to specify custom rung spacing |
Opens the Custom Rung Spacing dialog box, to specify the spacing between each ladder rung. Enter the distance between the rungs; the distance from top updates automatically. Click Calculate Even Spacing to automatically space the rungs evenly, as a starting point for spacing or to reset the values; the first and final distances are automatically calculated. To set the top rung to the position at the top of the ladder, click Set Top to Top. To set the bottom rung to the position at the bottom of the ladder, click Set Bottom to Bottom. The position of the other rungs does not change. |
Position Name |
Enter a name for identification and reporting purposes. When the lighting pipe ladder is used as a hanging position, this name automatically populates the Position field of any attached load objects. |
Index |
Specifies a unique identifier for the ladder, which is combined with the Position Name for identification and reporting |
Location |
Optionally, specifies the location for use in reports |
Weight |
Displays the total weight of the lighting pipe ladder |
Pipe |
Draw Pipe |
Shows or hides the 2D component of the lighting pipe ladder |
Line Type |
Select either a single or double line for Top/Plan views |
Curved Top |
Creates a ladder with a curved top |
Measure first rung from |
Select whether to measure the first rung from the top or the arc or base of the arc |
Show Snap Guide |
Displays a snap guide |
Rungs |
Diameter |
Sets the rung diameter |
Render Profile |
Select the 3D profile of the rung; this setting affects rendering speed (shapes other than round may render more quickly) |
Sides |
Verticals |
Select where to draw the vertical supports |
Profile |
Select the side profile |
Diameter |
Sets the pipe diameter for the sides |
Depth |
For rectangular profiles, set the depth |
Construction Material |
Select the material (aluminum, steel, and so on) of the lighting pipe ladder |
Wall Thickness |
Specifies the thickness of the pipe wall |
Tick Mark |
Display ticks as |
Choose how to display evenly-spaced marks to assist with lighting device placement; all options except None also provide master snap points along the lighting pipe ladder when hovering over it. |
Centers |
Specifies the distance between tick mark centers |
Snap intervals between ticks |
Specifies the distance between master snap points |
Origin |
Starts the tick mark placement at the center of one side of the ladder or split equally from the center of one of the ladder sides
Type |
Select Line or Dot as the 2D tick mark indicator |
Size |
Specifies the length of line tick marks or the diameter of dot tick marks |
Gap Length |
Adds a gap on either side of the tick mark; specify the gap length |
Offset |
Specify a positive or negative value to shift the tick marks right or left from their centers |
Align Tick Marks to Grid |
Aligns the center tick mark with the snap grid (see Snapping to the grid); this does not change the tick mark spacing but it may change the Offset value |
Classes |
Use Standard Classes |
Opens the Use Standard Classes dialog box to set the class prefix used by the pop-up class settings below. Select Existing class to use an existing class from the document as a prefix. Select Other prefix to create a new custom prefix without creating the class. |
List of lighting pipe ladder parts |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Lighting Pipe Ladder Class> to place the part attributes in the same class as the lighting pipe ladder object. |
Opens the Lighting Ladder Settings dialog box, to set the default class for the lighting pipe ladder. Select the Make default for new documents option to always use the specified class as the default class for lighting pipe ladder objects in new files. |
