Circuiting tool
Tool |
Tool set |
Circuiting
MEP |
Once electrical or communication panels and objects have been inserted, the Circuiting tool links the objects by assigning each item a circuit number and associating it with a panel board.
The symbol or object that is being circuited must be on a visible (not grayed) layer. If the symbol is not on the active layer, the symbol is copied to the active layer, and then the record information is attached. This is designed so that an electrical engineer can use referencing to access architectural layers with preliminary outlet locations. The engineer can then copy those outlets to the proper layer without re-entering data.
