Editing circuits
Tool |
Tool set |
Edit Circuiting |
MEP |
The Edit Circuiting tool modifies existing circuit information. Use this tool to reassign circuit numbers and update the information attached to the circuited elements.
To edit existing circuits or a circuited item:
Click the tool.
Click the circuited item to be edited.
The Edit Circuit Tool dialog box opens.
Parameter |
Description |
List of editing operations |
Selects the editing operation to perform. Select Edit circuit information only to edit the information which applies to the entire circuit. Select Edit selected item only or Edit all items on the circuit to enter edits which apply only to the selected circuiting item or edit both circuit and circuited object information. Select Delete selected item only or Delete entire circuit to delete the circuited item from the circuit or delete the entire circuit (the circuited items remain on the drawing). |
Circuit to Edit |
Selects the specific circuit to edit; available if selected item has multiple circuit assignments associated with it |
Circuit Information |
Enter the circuit information (used on the panel schedule) |
Panel Name |
Select the associated panel |
Circuit # |
Enter the circuit number |
Trip |
Enter the trip rating |
Wire Size |
Enter the size of the wire |
Conduit Size |
Enter the conduit size |
V.A./Watts |
Enter the total V.A./Watts rating |
Remarks |
Enter remarks about the circuit |
Check Voltage and Phase of Circuit Items |
Verifies that the voltage and phase of circuit items is correct |
Item Data |
Enter parameters for the object being circuited |
Phase/Pole |
Enter the number of phases/poles |
Voltage |
Enter the voltage |
V.A./Watts |
Enter the V.A./Watts for this object |
Remarks |
Enter remarks for the object |
Select the operation to perform.
If there are multiple records attached to this item, select the record to edit from the Circuit To Edit list. The record information displays in the Circuit Tool dialog box.
