Change Vertex mode
Mode
Tool
Tool set
Shortcut
Change Vertex
Reshape
Basic
- (hyphen)
This mode changes an existing vertex to a different type of control point: corner, Bézier, cubic, radius, or fillet (circular arc) point.
To reshape a 2D polyline or polygon by changing a vertex:
Select the polyline or polygon to reshape.
Click the tool and mode.
From the Tool bar, select the new type of control point for the vertex.
Change vertex does not work on a midpoint handle. Select only a vertex point.
Click a vertex to change it to the new type.
Reshaping objects
Converting polyline vertices from arc to radius
Editing vertex-based objects
