Design SuiteCreating parking spaces
Tool
Workspace: Tool set
Parking Spaces
Architect and Landmark: Site Planning
Spotlight: Building Shell
To create basic parking spaces:
Click the tool.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited from the Object Info palette.
Parameter
Description
Rotation
Specifies the number of degrees to rotate the object (0.00 is horizontal)
Text Style
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text.
Space Style
Select the type of parking space:
Single Bay: Draws spaces on one side of the header stripe
Double Bay: Draws spaces on both sides of the header stripe
Parallel: Creates parallel spaces (along a curb, for example) instead of head-in parking
No. of Standard Spaces
Specify the number of spaces to create
Space Width
Indicates the parking space width
Space Length
Indicates the parking space length (for parallel spaces, this is the length along the curb)
Space Angle
For single and double bay parking, specifies the angle of each parking space
Header Style
Select the header style:
Straight: The header stripe remains straight
Angled: The header stripe stays perpendicular to the space angle
No. of Accessible Spaces
Specifies the number of spaces with a different width applied for accessibility
Accessible Width
Sets the space width for accessible spaces
Accessible Location
Indicates whether the location of the accessible space(s) is at the beginning or end of the parking row
Show Accessible Symbol
Displays an accessible parking symbol in each designated parking space.
The software’s library includes an international standard accessibility symbol that can be edited by the user.
Add Accessible Aisle Spaces
Adds aisle spaces adjacent to accessible parking spaces
Aisle Width
Enter a value for the accessibility aisle width
Aisle Location
Select an aisle location relative to the accessible parking spaces
Aisle Fill
Click to open the Choose Fill dialog box, and select the aisle fill from options present in the drawing (see Fill attributes)
Show Header Stripe
Toggles the display of the parking header stripe
Show Start Stripe
Toggles the display of the side of the first parking space
Show End Stripe
Toggles the display of the side of the last parking space
Space Numbering
Adds a parking space number to each parking space; spaces are numbered from left to right and top to bottom
Start Numbering At
Specifies the starting number to begin parking space numbering
Show Bumpers
Toggles the display of the parking space bumpers (stops)
Show 3D Stripes
Toggles the display of the parking spaces in a 3D view
Parking tools
