Design SuiteEditing sketch styles
Command
Path
Shortcut
Sketch Options
View > Rendering
Ctrl+Shift+Alt+S (Windows)
Cmd+Shift+Option+S (Mac)
Edit the settings for the pre-defined sketch styles as needed. To create a custom sketch style, enter a unique name.
Sketch styles do not display in the Resource Manager until a sketch-related option is selected the first time.
To edit a sketch style:
Select the command.
The Sketch Options dialog box opens.
Select a style and click Edit.
The Sketch Style Editor dialog box opens. The preview graphic provides help with editing.
Parameter
Description
Name
If you edit a pre-defined style and change the name, a new style is created. The name must be unique within this file.
Edge Settings
Wobble
Controls how much the sketched lines are offset from the true lines of an object; drag the slider to the right to increase the wobble
Stroke
Controls the length of the sketch drawing strokes; a longer stroke distance increases the number of wobble points. Drag the slider to the right to increase the number of wobble points.
Randomness
Controls the amount of wobble and stroke variation
End Point Settings
Overstrike
Extends sketched lines past their endpoints; drag the slider to the right to increase the overstrike distance
Understrike
Shortens sketched lines before their endpoints; drag the slider to the right to increase the understrike distance
Randomness
Controls the amount of overstrike and understrike variation
Alternatively, from the Resource Manager, right-click on the resource, and select Edit from the context menu. Sketch styles can also be deleted and/or replaced from the Resource Manager (see Deleting or replacing resources).
Sketch rendering
Creating custom sketch styles
