Creating a sheet list
Command |
Path |
Create Sheet List |
Tools > Reports |
The Create Sheet List command compiles the current title block border information for use as a sheet list index or worksheet.
To create a sheet list index:
Select the command.
The Create Sheet List dialog box opens.
Parameter |
Description |
US Arch Title Block Entries |
Lists the current title block border objects |
Sheet No. |
Displays the contents of the current title block selection |
Add > |
Moves a selected item from the US Arch Title Block Entries list to the Proposed Sheet list |
< Remove |
Removes a selected item from the Proposed Sheet list and displays it in the US Arch Title Block Entries list |
New |
Click to open the New List Entry dialog box and add the drawing and title block information to the Proposed Sheet list |
Move Up/Move Dn |
Moves the selected title up or down in the Proposed Sheet list |
Format |
Click to open the Sheet List Index Preferences dialog box and specify whether to create the sheet index as a text block or worksheet; also specify formatting criteria |
Proposed Sheet List |
Lists the proposed title block borders to include in the sheet list |
Sheet No./Title |
Displays the contents of the current selection for editing |
Move the desired title block border entries to the proposed sheet list to create the sheet list, and format the list by clicking Format; select whether to create a text object or worksheet from the list.
Click OK.
If the sheet list index is formatted as a text block, click to select the top left and bottom right corners of the sheet list area; the text wraps to fit within this width. If the sheet list index is formatted as a worksheet, click to add the worksheet to the file.
