Regular (equal-sided) polygon
Use the Regular Polygon tool to create single-line closed polygons in which all sides of the polygon are the same length. The Push/Pull mode is available in 3D views for instantly extruding the polygon after creation.
Mode |
Description |
Inscribed
Creates a polygon by drawing its radius to a corner |
Circumscribed
Creates a polygon by drawing a radius to the mid-point of a side |
Edge
Creates a polygon by drawing one of its sides |
Push/Pull (3D views only)
Instantly extrudes the polygon after creation; see Push/Pull mode of planar tools |
Push/Pull Combine (available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged |
Number of Sides |
Sets how many sides the polygon has (from 3 to 4000) |
Press and hold the Option (Mac) or Ctrl (Windows) key while drawing to toggle between circumscribed and inscribed modes.
Regular polygon by inscription
Mode |
Tool |
Tool set |
Shortcut |
Inscribed
Regular Polygon
Basic |
Alt+Shift+R (Windows) Option+Shift+R (Mac) |
To create a regular polygon by inscription:
Click the tool and mode.
Enter the Number of Sides for the polygon (a number from 3 to 4000).
Click to set the center of the polygon.
Click to set the corner radius.
Regular polygon by circumscription
Mode |
Tool |
Tool set |
Shortcut |
Circumscribed
Regular Polygon
Basic |
To create a regular polygon by circumscription:
Click to set the edge radius.
Regular polygon by edge
Mode |
Tool |
Tool set |
Shortcut |
Edge
Regular Polygon
Basic |
To create a regular polygon by edge:
Click to set a corner of the polygon.
Click to set an adjacent corner of the polygon and define an edge.
