Creating 3D polygons
Tool
Workspace: Tool set
3D Polygon
Fundamentals, Architect, Spotlight: 3D Modeling
Landmark: 3D Modeling and Site Planning
The 3D Polygon tool creates polygons that have a location in 3D space, but no height. The polygon can be created through any 3D point, not necessarily constrained to the working plane. The Push/Pull mode is available in 3D views for instantly extruding the polygon after creation.
Mode
Description
Push/Pull
(3D views only)
Instantly extrudes the polygon after creation; see Push/Pull mode of planar tools
Push/Pull Combine
(available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged
To create a planar 3D polygon:
Click the tool.
Click to set the polygon’s start point (first vertex).
Click at each vertex.
Double-click at the final vertex to end an open polygon; click at the starting vertex (a point cue displays) to end a closed polygon (the first and last vertex are automatically joined).
Closing and opening polygons and polylines
Displaying and reversing object direction
Reshaping 3D polygons
