Design SuiteDownloading from AutoTURN Online
Command
Workspace: Path
Get Analysis from AutoTURN Online
Architect: AEC > AutoTURN Online
Landmark: Landmark > AutoTURN Online
Spotlight: Spotlight > AutoTURN Online
Once the swept path analysis is complete, the color-coded analysis envelopes, path polyline, and data can be inserted back into the Vectorworks drawing.
To download the analysis from AutoTURN Online and place it in Vectorworks:
Do one of the following:
Select the command. (If you are not logged in to AutoTURN Online, start by Logging in to AutoTURN Online.)
If you are already in the AutoTURN Online browser, click Close and Get Analysis.
The Get Analysis from AutoTURN Online dialog box opens.
Parameter
Description
Saved Settings Options
See Using saved sets to save and apply saved settings
Drawing
Lists all drawings saved on the AutoTURN Online servers; select the drawing to download
View in AutoTURN Online
Opens the selected drawing in the AutoTURN Online browser to verify the status of the drawing
Get Analysis objects
Determines which elements of the AutoTURN Online drawing to download into the Vectorworks file
Vehicle swept path as polylines
Downloads the swept path analysis; in Vectorworks, these are grouped polyline objects
To Design Layer/In Class
To control appearance and visibility, select the design layer and class for the downloaded items from the list of layers and classes present in the drawing, or create a new layer or class
Vehicle profile and dimensional details
Downloads the label with the description of the vehicle’s profile and data (must be added first in AutoTURN Online by clicking Place Vehicle Profile in Drawing)
Previously sent geometry
Downloads the linework that was uploaded previously, as polylines
Previously sent background image
Downloads the background image snapshot
The analysis polylines and other downloaded items are inserted into the current Vectorworks file as groups.
Logging in and out of AutoTURN Online
Working with AutoTURN Online
Simulating vehicle circulation with AutoTURN Online
