Editing a stair
Once a stair has been created, there are multiple ways to edit it:
Reshape its overall dimensions using the Reshape tool.
Edit stair parameters in the Stair Settings dialog box. To access it, click Settings from the Object Info palette, double-click the stair, or right-click on a stair and select Edit from the context menu.
Edit some parameters directly from the Object Info palette.
Use the Stair tool's Pick up Mode and Apply mode to transfer stair properties from one stair to another.
