Design SuiteResetting plug-in objects from previous versions
Command
Path
Reset All Plug-ins
Tools > Utilities
When you migrate plug-in objects from previous versions, some Object Info palette parameters display when they should be hidden. In addition, a plug-in object's script may have changed, and drawing objects need to be refreshed. Select the Reset All Plug-ins command to execute a refresh.
To reset plug-in objects:
Open an older drawing containing plug-in objects.
Select the command.
The Reset All Plug-ins dialog box opens.
Click Yes to reset plug-in objects.
A message displays the update status. When complete, the Object Info palette displays only the pertinent parameters, and any affected drawing objects are reset.
