Saved views
A saved view is like a camera that is set up to show a drawing from a certain orientation, with a specific set of viewing parameters, including which class and design layer are active, the visibilities of the inactive classes and the design layers, the current zoom and pan, and the page location. If Vectorworks Design Suite is installed, the plan rotation and the clip cube position can be saved.
Views are also used to create animations (see Creating a walkthrough animation from saved views for more information), and transition animation is supported when changing between saved views. The transition animation settings between saved views can be customized.
Creating saved views
Editing saved views
Creating or editing saved views using the saved views menu
Organizing the drawing
