Changing plug-in object styles from the Object Info palette
Plug-in object styles applied to existing objects can be replaced or edited from the Object Info palette.
Replacing object styles
To replace the style of a selected object:
Select one or more objects.
From the Object Info palette, select Replace from the Style list.
The Choose a Plug-in Style dialog box opens.
Select the new style. For most object types, the replacement style is automatically applied to all selected objects.
Some object types, such as plants, provide a choice whether to replace the style of all selected objects or of all instances in the drawing that use the replaced style; select the appropriate option.
Editing object styles
To edit the style of all objects with the style:
Select an object.
From the Object Info palette, select Edit Style from the Style list.
The <Object> Style dialog box opens.
Edit the current style, as described in Creating plug-in object styles.
Editing a plug-in object style modifies all instances in the drawing that use that style.
Converting objects to unstyled
To convert the instance to unstyled:
From the Object Info palette, select Convert to Unstyled from the Style list.
The object’s current values are retained, but all parameters are set to By Instance to allow editing.
