Design SuiteJoining wall components
Tool
Tool set
Component Join
Building Shell
The Component Join tool joins the selected components between two straight wall segments; components within pre-existing joined wall segments can also be joined. There are three modes for joining wall components.
Mode
Description
T Join
Extends or shortens one wall component segment until it intersects with a second wall component segment
L Join
Joins the closest ends of two wall components to create a corner
Capped Join
Applies a capped join to the component being joined
Components can be joined to the edge of walls instead of specific components in Capped Join mode.
Normally, when you join walls with the Wall Join tool, and the Auto-join walls preference is enabled, the components automatically join correctly. A core component must be set. (See Joining walls.)
The Component Join tool is useful for adjusting components that did not join as desired when walls were connected, even in complex wall joins.
Capped wall component joins
Hiding wall components
Joining walls
Automatically joining walls
Creating walls
