Data bar options
The Data bar is controlled by the Data Bar Options quick preference; the commands can also be selected from the Window menu.
Menu command |
Description |
Location of the Data bar fields |
Use floating data bar |
The Data bar floats with the cursor in the drawing area |
Use floating data bar only when tab key is pressed |
The Data bar floats with the cursor only when the Tab key is pressed; otherwise the bar does not display |
Allow numeric keypad entry for instant data bar activation |
When the floating Data bar is displayed, enter numbers on the keyboard or numeric keypad to activate the first field |
Do not allow numeric keypad entry for instant data bar activation |
When the floating Data bar is displayed, enter numbers on the keyboard only to activate the first field |
Do not allow instant data bar activation |
When the floating Data bar is displayed, press the Tab key to activate the first field |
Field display on the Data bar |
Show only primary fields on data bar |
Show only the primary data fields (for example, L and A for circles) |
Show primary and secondary fields on data bar |
Show all fields except the cursor location fields (X and Y) |
Show primary, secondary, and cursor location fields on data bar |
Show all fields |
Field cycling options |
Auto cycle to non-displayed fields when tabbing past last field |
When some of the data fields are hidden, press the Tab key in the last visible field to make the non-displayed fields become visible |
Do not auto cycle to non-displayed fields when tabbing past last field |
When some of the data fields are hidden, press the Tab key in the last visible field to return to the first field |
Location of the floating Data bar |
Show floating data bar below SmartCursor cues |
When the floating Data bar is enabled, displays the Data bar below the SmartCursor cues (below the cursor) |
Show floating data bar above SmartCursor cues |
When the floating Data bar is enabled, displays the Data bar above the SmartCursor cues (above the cursor) |
Data bar activation on datum creation |
Show floating data bar after datum creation |
When the floating Data bar is enabled, displays the Data bar automatically after a datum is set |
Do not show floating data bar after datum creation |
The floating Data bar does not automatically display after a datum is set. Press the Tab key to display the floating Data bar. |
