Constrain angle
Tool |
Workspace: Tool set |
Constrain Angle
Fundamentals, Architect, Spotlight: Dims/Notes Landmark: Basic |
Multiple constraint tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Constrain the angular relationship between separate objects or line segments of a single object. If one object or segment is moved, the other constrained object moves to maintain the angle.
To constrain the angle between objects or line segments of a single object:
Click the tool.
Click an object to constrain.
Click a second object to create the constraint.
A green angle constraint is drawn between the two objects or line segments.
