Constrain horizontal distance
Tool |
Workspace: Tool set |
Constrain Horiz Distance |
Fundamentals, Architect, Spotlight: Dims/Notes Landmark: Basic |
Multiple constraint tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Constrain the horizontal distance between two points—either the endpoints of a single line segment or object edge, or endpoints on two separate objects. If an object resize is attempted, the constraint prevents the operation, preserving the original horizontal distance. When the constraint is on two different objects, if one object is moved, the other constrained object moves to remain at the same constrained horizontal distance.
To constrain the horizontal distance between endpoints on a single object:
Click the tool.
Click the object to constrain.
A green horizontal distance constraint is drawn on the object.
To constrain the horizontal distance between endpoints on separate objects:
Click the tool.
Click an endpoint to constrain.
Click a second endpoint to create the constraint.
A green horizontal distance constraint is drawn between the two points.
