Constrain perpendicular
Tool
Workspace: Tool set
Constrain Perpendicular
Fundamentals, Architect, Spotlight: Dims/Notes
Landmark: Basic
Multiple constraint tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Constrain linear objects to be perpendicular to one another. If one object is moved, the other constrained object moves to remain perpendicular to the first object. If the lines aren't perpendicular when you place the constraint, the first line moves to become perpendicular to the second line.
To constrain linear objects to be perpendicular:
Click the tool.
Click a line or line segment to constrain.
Click a second line or line segment to create the constraint.
A green perpendicular constraint is drawn, connecting the two lines.
