Exporting calculation results
Command |
Workspace: Path |
Export Braceworks Structure |
Design Suite: Entertainment > Rigging/Braceworks Reports Spotlight: Spotlight > Rigging/Braceworks Reports |
To export the results of the last calculation:
Select the command.
The Export Braceworks Structure dialog box opens.
Parameter |
Description |
Export Format |
Select whether to export to an .stp file in DSTV format or to a SCIA Engineer XML format |
Load Combination |
Select <No Load Combination> or choose a load combination. The icon next to the combination indicates whether it is class- or layer-based. |
Selection |
Select whether the exported results should include all rigging objects in the drawing, or only a subset of selected or visible objects |
