Sheet metal screws
Mode
Tool
Tool set
Sheet Metal Screw
Detailing
The Sheet Metal Screw tool and Sheet Metal Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a sheet metal screw (self-tapping screw):
Click the tool and mode.
Parameter
Description
View
(2D only)
Select the 2D view
Series
Select inch or metric to display the appropriate nominal sizes
Head Type
Select the sheet metal screw head type
Slot Type
Specify the slot type
Point Type
Select the sheet metal screw point type
Nominal Size
Select an inch or metric nominal size
Length
Enter the length under the screw head (or overall length for flat head screws)
Show Threads
Draws the sheet metal screw with threads
Show Center Line
(2D only)
Draws the sheet metal screw with center line(s)
Inserting fastener objects using the Fastener tool
Lag Screw tool
Thumb screws
Wood screws
