U-bolts
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
U-Bolt
Fasteners |
The U-Bolt tool and U-Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a U-bolt:
Click the tool and mode.
Parameter |
Description |
Size |
Specify the U-bolt size in diameter/threads per inch (imperial) or diameter/thread pitch (metric) |
Inside Distance |
Specify the inside distance between the ends of the U-bolt |
Length |
Specify the length from the inner portion of the “U” to the end of the legs |
Thread Length |
Specify the thread length |
Thread Style (2D only) |
Select the thread style; see Fastener object thread styles |
View (2D only) |
Select the 2D view
Show Center Line (2D only) |
Draws the U-bolt with center line(s) |
Place Locus at Center |
Draws the U-bolt with a center locus
Show Threads (3D only) |
Draws the U-bolt with threads
