Bevel gears
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Bevel Gears
Architect and Spotlight: Machine Components Landmark: Add tool to workspace |
The Bevel Gear tool and Bevel Gear - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
A bevel gear set consists of a gear and pinion.
To insert a bevel gear:
Click the tool and mode.
Parameter |
Description |
View (2D only) |
Select the 2D view
Value to Use |
Select either Diametral Pitch or Module, and then enter the relevant parameter |
Diametral Pitch |
Enter the diametral pitch |
Module (mm) |
Enter the module |
Shaft Angle (deg.) |
Enter the shaft angle in degrees |
Face Width |
Enter the face width |
Configuration |
Select to use the gear parameter values for only the gear, only the pinion, or for both the gear and the pinion; this can also be used to create miter gears |
Gear Properties |
Specify the parameters to draw the gear |
No. of Teeth |
Enter the number of teeth |
Pitch Dia. (Ref.) |
Displays the pitch diameter based on the diametral pitch and number of teeth |
Mounting Distance |
Enter the distance from the back of the gear to the pitch apex |
Hub Diameter |
Enter the hub diameter |
Hub Projection |
Enter the hub projection, for styles with a projected hub |
Bore Diameter |
Enter the bore diameter |
Key Type |
If the gear includes a keyway, select keyway shape (with ASME-recommended sizes), or select Custom size |
Kwy Width/Height |
For custom keyway sizes, enter the keyway width and height |
Recess |
If the gear has a recess, enter the recess value |
Fillet Radius |
Enter the fillet radius of the hub |
Pinion Properties |
For pinion only or gear and pinion configurations, specify the pinion parameters |
No. of Teeth |
Pitch Dia. (Ref.) |
Mounting Distance |
Enter the distance from the back of the pinion to the pitch apex |
Hub Diameter |
Hub Projection |
Bore Diameter |
Key Type |
If the pinion includes a keyway, select keyway shape (with ASME-recommended sizes), or select Custom size |
Kwy Width/Height |
Recess |
If the pinion has a recess, enter the recess value |
Fillet Radius |
Show Pinion at Left (2D only) |
Displays the pinion on the left side of the bevel gear |
Draw Center Lines (2D only) |
Draws the bevel gear with center lines |
Show Teeth (3D only) |
Draws the bevel gear with teeth
Spiral Angle (Deg.) (3D only) |
Draws a 3D spiral bevel gear; specify the spiral angle degrees for the teeth |
