Dowel pins
Mode
Tool
Tool set
Dowel Pin
Fasteners
Multiple dowel pin and parallel pin tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a dowel pin:
Click the tool and mode.
Parameter
Description
Dowel Pin Type
Select the type of ANSI dowel pin
Nominal Size
Select a nominal size in inches
Length
Enter the pin length
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the dowel pin with center line(s)
