Retaining rings and washers
Retaining rings
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Retaining Ring
Fasteners |
Multiple retaining ring and retaining washer tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a retaining ring:
Click the tool and mode.
Parameter |
Description |
Type |
Select the retaining ring type |
ASME |
DIN |
Size (mm) |
Select the retaining ring size in millimeters |
View (2D only) |
Select the 2D view
Place Locus at Center |
Adds a locus at the center of the retaining ring
