Worm gears
Mode
Tool
Workspace: Tool set
Worm Gears
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple worm and worm gear tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a worm gear:
Click the tool and mode.
Parameter
Description
Circular Pitch
Enter the circular pitch
Number of Teeth
Enter the number of teeth
Pitch Diameter (Ref.)
Displays the pitch diameter of the gear, based on the pitch and number of teeth
Pressure Angle (deg.)
Select the pressure angle in degrees
Number of Starts (Worm)
Select the number of starts of the worm
Pitch Dia (Worm)
Specify the worm pitch diameter
Tooth Profile
Select the type of tooth profile
Face Width
Enter the width of the gear face
Draw Recess
(2D only)
Select Draw Recess to draw a recessed web, and specify the 2D parameters
Web Thickness
Enter the web thickness
Recess Diameter
Enter the recess diameter
Recess Corner Radius
Specify the recess corner radius
Recess Fillet Radius
Indicate the recess fillet radius
Draw Hub
(2D only)
Draws a hub
Hub Diameter
Enter the hub diameter
Hub Projection (Left/Right)
Specify the amount of projection for the hub on both the left and the right; a negative value indicates that the hub face is recessed
Hub Corner Radius
Enter the hub corner radius
Hub Fillet Radius
Enter the hub fillet radius
Draw Bore
(2D only)
Draws a bore
Bore Diameter
(2D and 3D)
Enter the bore diameter
Keyway
If a keyway is present, select the square, rectangular, or custom size. The square and rectangular selections apply the ASME-recommended size based on the bore diameter.
Width/Height
For custom keyway sizes, enter the width and height values of the keyway
Web Configuration
(2D only)
Select the gear configuration and then specify the 2D parameters, if any. When Holes is selected, hole size can be specified as a percentage or diameter value.
Number
Indicate the number of holes or spokes for the gear (does not apply to Plain web configurations)
Size (10–100%)
For Holes (Percent) and Spokes web configurations, enter the percentage of the recess opening occupied by the holes or spokes
Center Distance
When Holes is selected for the web configuration, specify the distance between the hole centers
Hole Diameter
When Holes is selected for the web configuration, indicate the size of the holes
View
(2D only)
Select the 2D view
Show Center Lines
(2D only)
Draws the gear with center lines
Worms
