Torsion springs: End view and 3D
Mode |
Tool |
Workspace: Tool set |
Modes for The Symbol Insertion tool |
Torsion Spring - End
Torsion Spring - 3D
Architect and Spotlight: Machine Components Landmark: Add tool to workspace |
Multiple torsion spring tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a torsion spring - end view:
Click the tool and mode.
Parameter |
Description |
Wire Diameter |
Enter the wire diameter |
Outside Diameter |
Specify the outside diameter of the coiled section of the torsion spring |
Number of Active Coils (3D only) |
Specify the number of active coils in the coiled section of the 3D torsion spring |
End # 1/2 |
Select to enter the dimensions for End #1 and/or End #2 |
Length |
For each end, specify the length between the coil center and the bend |
Deflection |
Enter the deflection angle for each end |
End Style |
Select a style for each end (specify a clockwise (CW) or counterclockwise (CCW) direction)
Bend Radius |
For each end, specify the radius value of the bend (does not apply to Plain End Styles) |
Bend Length |
For each end, specify the length between the bend and the wire end (does not apply to Plain or Full Loop End Styles) |
Spiral |
Select either a Left Hand or Right Hand spiral direction |
