Angular dimensioning
Tool |
Workspace: Tool set |
Shortcut |
Angular Dimension
Fundamentals: Dims/Notes Architect, Landmark, Spotlight: |
. (period) |
The Angular Dimension tool measures and dimensions angles. Dimension the angle between two object edges, between two sides of a single object, between a single object and a reference line, or between two reference lines.
This tool works with all objects with linear or planar sides, including rounded and rotated rectangles, lines, polylines, polygons, and solids. It does not, however, work with circles, ovals, or arcs. In addition, it cannot dimension between parallel lines or lines on different planes.
If Snap to Working Plane is enabled in the Snapping set, the face of the object being dimensioned must be parallel to the working plane.
Mode |
Description |
Edges
Dimensions the angle between two object edges or faces |
Reference Line and Edge
Dimensions the angle between an object and a reference line |
Reference Lines
Dimensions the angle between two reference lines |
Dim Std |
To change the dimension standard for new dimensions created in the document, select a standard from the list; select Custom Standards to create or manage custom dimensions (see Using custom dimension standards) |
