Diametrical dimensioning inside circle/arc
| Mode | Tool | Workspace: Tool set | Shortcut |
| Internal Diametrical
 | Radial Dimension
 | Fundamentals: Dims/Notes Architect, Landmark, Spotlight: | , (comma) |
The Internal Diametrical mode measures and dimensions the diameter of a circle or arc, and places the dimension inside the object.
To create a diameter dimension inside a circle or arc:
Click the tool and mode, and then select a Dim Std (dimension standard).
Click on or within the arc or circle to dimension.
Move the cursor to preview the dimension line location.
Click to place the dimension.
