Design SuiteFeature control frame
Mode
Tool
Workspace: Tool set
Feature Control Frame
Architect and Spotlight: Dims/Notes
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
A feature control frame consists of a geometric characteristic symbol, up to two tolerance areas, and up to three datum reference areas.
To insert a feature control frame:
Click the tool and mode.
To add a leader and marker, click the Selection tool from the Basic palette and drag the control points on the object. Edit the marker from the Attributes palette (see Marker attributes).
Parameter
Description
Rotation
Specifies the number of degrees to rotate the object (0.00 is horizontal)
Text Style
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text.
Geometric Characteristic
Select the geometric characteristic symbol, if any
Composite Box
Increases the size of the geometric characteristic box; this is used when placing a second feature control frame
Tolerance Area #1/#2
Includes Tolerance Area #1 and/or Tolerance Area #2
Tolerance
Enter the tolerance value
Show Diameter Symbol
Displays a diameter symbol along with the tolerance value
Material Condition
Choose the material condition, if any
Statistical Tolerance
Displays a statistical tolerance symbol
Projected Tolerance Zone
Displays a projected tolerance zone symbol
Zone Height
Enter the maximum projected tolerance zone height when a projected tolerance zone symbol is displayed
Place the PTZ symbol outside the FCF
Places the projected tolerance zone symbol outside and to the bottom of the feature control frame
Primary/Secondary/Tertiary Datum Reference
Includes the primary, secondary, and/or tertiary datum reference
Reference
Enter the desired reference letter
Material Condition
Select a material condition, if any
Leader Position
Select left or right
Geometric dimensioning and tolerancing
Marker attributes
