SpotlightFormatting speaker object labels
A variety of speaker and speaker array labels can be included in the drawing. Different options are available for speakers and speaker arrays. A speaker array, as well as the individual speakers that make up the array, can be labeled.
To select labels for display and format the text:
Select a speaker or speaker array object (bumper). From the Object Info palette, click Text Options.
The Text Options dialog box opens.
Parameter
Description
Elements to Show
Select items to add to the text label; different label elements are available for speakers and speaker arrays
Round off dimensions
Rounds dimensions to the nearest inch or millimeter
Labels
Includes the name of the element along with the value; deselect this option to display the parameter value only
Text Attributes
Keep text horizontal
Maintains the text in a horizontal position even when the object is rotated; deselect this option to rotate the label along with the object
Fill text background
Allows a text background fill to be used for all speaker text; by default, white is used as the fill color. To specify a different fill color, click Classes in the Object Info palette, and then select a fill color for the class of the speaker text. The class should be set to Use at Creation.
Text formatting options
Specify the text size, color, and alignment
Bubble and Leader Settings
Specify the bubble type, leader type, and their attributes
Specify the text label elements and formatting.
Once the label has been added to the drawing, it can be moved by clicking and dragging the label control point. Click Default Text Position from the Object Info palette of a selected speaker or array object to restore the text label(s) to the original location.
Inserting speakers and speaker arrays
Inserting speakers
Inserting speaker arrays
