ArchitectInserting bathtubs and showers
Mode
Tool
Tool set
Bath-Shower
Furn/Fixtures
The Bath-Shower tool provides access to a variety of standard configurations available from the Resource Manager, in addition to individual objects created using the tool. The tool can be used to create your own style resources (see Concept: Plug-in object styles).
To insert a bathtub or shower fixture:
Click the tool and mode.
Do one of the following:
Click Bath-Shower Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide Style Parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Depth
Enter the fixture depth
Width
Enter the fixture width
Rim Height
Enter the fixture’s rim height
Config
Select the shape of the bathtub or shower
Surround
Creates a surround for the fixture; enter the surround height
Back Ledge
Creates a back ledge for the fixture; enter the ledge’s width and height
Bevel
Enter the bevel size
Drain Offset
Enter the drain offset size
Side Thickness
Enter the thickness of the sides
Show 3D Detail
Displays the bath-shower in 3D views
Click on the drawing to place the object, and click again to set the rotation.
Optionally, create a style resource from the object (see Standard plug-in object styles without catalog options).
Symbols within a wall
